bp122
Expert at Jibber-Jabber
Hi all
I acquired a used Axminster planer thicknesser earlier this year. By the looks of it, it appears to be a copy of the Record PT260 with slightly flimsier plastic guards for belts and dust hood etc.
Anyway, as it happens with many, I hadn't run it until now. Just been buried at work etc.
I fired it up for the first time last night after setting it up to the best of my ability - fence perpendicular etc.
I noticed that despite the fence being perpendicular to the bed, when I plane a face and then reference that face on the fence and plane the edge, the edge isn't square to the face.
After a lot of sleuthing, I noticed at first glance, the fence appears to be perpendicular but closer inspection revealed a slight cup in it. In the image below, the green zones have the square making contact with the fence, but the red zone has a few ridges not making contact with the square. The imagined cup is exaggerated with the orange line.
This is due to the bit behind it which enables one to change the angle of the fence (see second image above). Here also, the orange line shows the exaggerated cupping of the casting. Which may be deforming the fence in that direction.
So I presumed my workpiece which was only reaching half the height or less on the fence, when the planed face was pressed against the fence, it was producing an obtuse angle on the workpiece edge.
So tried the same test with a wider workpiece which when the planed face was pressed against the fence and the edge was planed, it was still out by the same amount.
Has anyone had this issue? If yes, how did you solve it?
I am considering getting a 20x80mm aluminium extrusion which remains straight and using that instead.
Also, the blade guard which is supposed to apply pressure on the workpiece against the fence doesn't lock, it just moves with the slightest of force. There isn't an adjustment on it to tighten it. Any suggestions on this, please? Same with the height control lever for this guard. There isn't a lock to hold its position. It just plunges down with the slightest of force.
Any and all suggestions would be greatly appreciated.
Thanks in advance.
BP
Thanks in advance.
BP
