mike s":9iqehfkn said:
what are the pros and cons of this lathe?
thanks
Hi and welcome,
As I understand it, the M900 is the same as my Clarke CWL20RV.
It goes round - this is a definite Pro.
It has speed adjustment - another one
Its not the most solid - Con
Its not very powerful - Con. I can stop it doing anything but pretty fine cuts.
On mine at least the head and tail stocks do not line up - this can be adjusted with a bit of bodging but its not great.
For the price, the Axminster is probably good value as its considerably cheaper than the Clarke. However, I have had problems with spare parts as at some stage in its production run, the specs have been changed to the drive pulleys and I don't know if Axminster would be aware of it. My main concern is the lack of clearance between the drive pulleys and the casing. This makes changing a drive belt a bit tricky and its possible - as I did - to crack the front part of the split pulley when forcing -as you have to - the belt on.
My advice would be to try and spend more although I know about budgets clearly or I wouldn't be using one myself.
Having said all that, I have managed to do some reasonable stuff on mine and lets face it, some people create masterpieces on a foot lathe! I would try and find someone near to you on the forum who would be willing to let you try and see how it works.
