Yep, Girvan boy, left 24 years ago, I work in London but moved out here 3 years ago. I lived in Surrey before that so slowly moving North.
I don't think I'll move too much further North, I like this area, although I go home as the boys grandparents still there.
I take it you earn your living from working wood?
Spent today in the garage giving the planer a going over, I would have had it all done but spent yesterday wrestling with installing guttering on a shed. I thought I would have had it done in a couple of hours but the rain and the best laid plans got in the way so only managed today with the planer.
I managed to install the new NVR switch, with a bit of drilling of the cabinet and enlarging a hole in the base to fit a gland to take the new and uprated cable, bit fiddly but it looks a lot neater, no flex spilling out the front and all the connections are tidied away inside the base cabinet. Fitted the new link belt and adjusted the motor and alinged the pulleys so it now hums away quite the thing.
cleaned the tables and fence and waxed with wax furniture polish, vast improvement on before. Also managed to brush off most of the gunk and debris from most of the nooks and crannies and wiped down the cabinet to rid it of paint splats and the like. I Assembled and mounted the new mobile base. Checked and tightened a few nuts, bolts allen keys etc. I checked the planes of the two tables and they are near enough spot on ( I bought an engineers straight edge a few years back, I knew it would come in handy ) so I am happy with its setup now and satisfied the machine is safe to operate. All I have to do now is fit the 3 new knives.
The only problem I have encountered is that the safety guard post holder should be fixed to the base of the planer with 3 M4 bolts, unfortunately someone has sheared two of them off. So I have to try and extract them. unfortunately I think the only way I am going to be able to do this is take it all apart again and drill them out and re tap, bit of a pain having to strip it all down again as it will need to be turned up side down to get at them. I could use it as it is without compromising safety but it would niggle me knowing it wasn't right. I may have to wait until I have a bit more time though.
I'll be glad to get back to work for a rest!
