Setting up a workshop in a single garage and trying to decided which table saw to get. Will be using a track saw for sheet work but have always had a Table Saw and really like using them. The Axminster models seem to fit my budget and space available plus with induction motors are much quieter than others. Bid decision is do I need the AC254 with its 10" blade or would the smaller 216 be big enough ? TS 254 has 80mm at 90deg and 56mm at 45deg where as the TS 216 has 65mm and 45mm. 45mm@45deg is not enough for 2" timber & 65mm will not cut 3" timber. However the AC216 is quite a bit quieter not to mention cheaper!
How often do people need/use the extra capabilities of a 10" blade?
