• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Axminster 10” cast iron table saw 240v inc extentions, box joint jig.
Alpha-Dave
18 May 2015
Durham
Axminster AW10BSB2, comes with extention set: additional cast iron tables and longer supports for the fence.
Mitre guage and sub-rip fence inc
£800 all-in, collected from Durham.
I could deliver within a reasonable range, but we would have to discuss how that would work.
I would prefer it all to go together, but I could seperate the extensions, blades, jig etc. as separate lots depending if the buyer of the main saw wants them.
Model AW10BSB2
Rating Trade
Power 2.2kW 230V 1ph
Blade Dia/Bore 254 - 30 mm
Blade Tilt 0-45°
Max Depth of Cut @ 45 ̊ 60mm
Max Depth of Cut @ 90 ̊ 75mm
Max Width of Cut with Fence (with optional table extensions) 840mm
Max Ripping Width (with optional table extensions) 840mm
Table Size (incl side table) 800 x 830mm
Table Height 865mm
Table Size With Extensions 800 x 1,170mm
Dust Extraction Outlet 100mm
Min Extraction airflow 1,000m3/hr
Overall 1,170 x 800 x 865mm
Weight 184kg
Manual here: https://www.axminstertools.com/media/downloads/501197_manual.pdf
Small configuration
Large configuration (rear support table adds to the back)
box joint jig based on rails and a digital guage, also comes with a Cutting Solutions flat-top blade.
Crown guard,
Rear table:
    158.6 KB
    192 KB
