For what it's worth, I've got one of these and was impressed, yes it's an older model, but that's also good because it was made when Axminster was a brand that was worth something instead of the chinglish imported crap now.
I bought mine second hand also basically unused, brushes are a standard size so easy to replace and the collet has essentially zero "run out" that can be measured with a dial test indicator.
Oh it's also a true 1/2" not 12mm as often seems to be the case now, so 1/2" router bits won't slip.
