aesmith
The handles on both my axes were working loose. They're conventional old axes, no special splitting axes or anything, although they're almost exclusively used to split firewood.
Anyway I've extracted the wooden wedge from one, done some cleaning up of the head and done a bit of shaving of the handle so it fits tight on th handle side. It's not tight on the other side, the wedge will take up the side to side clearance but there is space top and bottom. The opening in the head is taller that side, so nothing that will fit through can ever be tight top/bottom.
How would the panel approach this? Starting with the easiest I could make the wedge full height. Or separate wedges top and bottom. Or something completely different.
Any comments welcome ..
