Boringgeoff
In our conversation on the Gedge bit, Andy T mentioned a auger bit with a detachable cutter which was described in the 1846 reference book: Volume 2 of Holtzapffel's "Turning and Mechanical Manipulation" and asked if I had one of these bits.
As it happens I do, a 5/8" branded Mathieson and the Crescent and Star trademark, no other marks that I can see. If we take the starting date of the mark as 1868 and the addition of "& Sons" as 1899 that gives a rough timeline for this bit. I have not been able to find a patent for the process of fitting the cutter (or spur) but I have found a patent criticising the attachment method.
On June 1st 1869 H. C. Lewis of Essex Conn. USA was awarded patent No 90,759, in part for "the peculiar manner of forming the spur upon the body of the bit". Lewis' criticism is "..fitting the spur in a separate piece, which often, by hard use, breaks out from the body of the bit and thus ruins the instrument."
https://patentimages.storage.googleapis ... S90759.pdf
Looking closely at my example there does appear to be a small gap between the spur and the body but I think the spur looks like it is dovetailed in so doubt that it will come out easily. The photo of the two together the upper is an unbranded example of Lewis' idea but don't know if it is related to him in anyway.
Cheers,
Geoff.
Cheers,
Geoff.
