Yojevol
Clocking on
I am making 'rustic' shelves from yew timber which feature lots of fissures and cracks which I am attempting to fill and stabilise with resin. The larger ones are up to 20mm wide and the full thickness deep - 36mm. These are mostly filled with rotted bark. I had assumed the resin would soak into the bark and stabilise it, however this is not the case. Where the resin has filled a free space it has fully cured but the rotted bark remains a guey mess. It would seem the resin has soaked in but not cured. Could this be because there is too much moisture present? The sound timber has a moisture content of 11% so would assume the bark is much the same.
I've also noticed that where resin has spread out over the clean shelf surface it has not adhered unless it is a very thin film. Anything over, say, 0.25mm remains uncured at the interface so I'm left with a resin lamina which easily flakes off.
Any advice greatly appreciated
Brian
Brian
