Phil Pascoe
Yes.
Not particularly. Tough and hard to work. Also prone to movement.Would beech be a sensible choice, I can get some at a reasonable price ... ?
They keep table tops flat and look better of course. I was asked recently to restore a mahogany table that had large splits in it. The top had breadboards joined with a machined joint and I'm guessing was a 1920's reproduction. It was placed next to a radiator and went ' bang ' in the night. I can only guess that they got away with this in houses that had no central heating as it wouldn't be done nowadays.More to keep the top straight and tidy particularly in taxing environments like kitchens with variable temperature/humidity etc.
Most tables including high class variations don't have them.
Bread board ends have to be a loose fit to allow movement. Probably what caused your table to split - no breadboards no problem.They keep table tops flat and look better of course. I was asked recently to restore a mahogany table that had large splits in it. The top had breadboards joined with a machined joint and I'm guessing was a 1920's reproduction. It was placed next to a radiator and went ' bang ' in the night. I can only guess that they got away with this in houses that had no central heating as it wouldn't be done nowadays.
I like it spaltedNot sure about spalted myself - I tend to think it's better as firewood.
My sycamore table tops are finished with Osmo oil which seems very tough, but in a trad kitchen they wouldn't be finished with anything except a regular scrubbing down.
Acoustic instruments, violin family, guitars etc, all ranges of quality, most commonly use spruce for the fronts and maple/sycamore for the body/neck, for good acoustic reasons! I guess sheer mass might be the bigger issue with electric..... I always looked down on pine for a guitar body until i noticed Fender custom shop do a pine body guitar!
Ash less good as the surface difficult to keep clean unless it's well sealed in. A waste of good wood too as it's excellent for tools, carts etc etc/. Sycamore most preferred as it cleans well and is useless for much else except music instruments (if it's at all rippled grain).Long and the short of it, if you want an Ash table make an Ash table! Do a google search and you'll see plenty of solid ash tables that I assume haven't all instantly fallen to pieces or twisted into knots.
not by the OP or anyone else wanting an Ash table.Sycamore most preferred
and possibly because of what was available at the time when guitars were developed. Sitars are made of teak as they were made in a country with access to teak back in the day. tradition does not always make something the best, they just didn't have a lot of alternatives when they were developed and it becomes a self fulfilling prophecy. Although it is likely with acoustics it will make more difference than electric, I was referring specifically to electric guitars though in this case, which other than having something strong enough not to break, just needs something to hold the electronics in place.Acoustic instruments, violin family, guitars etc, all ranges of quality, most commonly use spruce for the fronts and maple/sycamore for the body/neck, for good acoustic reasons! I guess sheer mass might be the bigger issue with electric.
everything has its pro's and con's, wood in general more difficult to keep clean than plastic or glass. So OP should make a plastic or glass topped table?!Ash less good as the surface difficult to keep clean unless it's well sealed in.
Ash grows very quickly and is quite sustainable. Ash die back is likely to result in a fair bit more entering the market that would otherwise be firewood. Very few people actually rehandle their own tools (although to be fair I do myself) and even if you do it doesn't require an awful lot to make a few chisel handles. Ash is the primary wood I burn as it grows so rapidly in our garden.A waste of good wood too as it's excellent for tools, carts etc etc/.
The round bits on a Sitar are made of a dried gourdnot by the OP or anyone else wanting an Ash table.
Yellow is typically the safest colour for cars but not so useful if you don't want a yellow car.
Sycamore scrubs clean very well. It was the most widely used trad kitchen table-top material. Looks good too.Ash is the only firewood that can be burned in it's green state. Nothing gets a fire going like it !.
Going back to the original OP question it would still be worth using Sycamore over Ash as it looks better as it matures. If anything the alternate rings of hard and soft grain in ash becomes more obvious as it ages and is not particularly attractive. Sycamore is a more homogenous wood and will acquire all the dings and stains of a kitchen table. Your children will thank you for the patina !
How did you sharpen the plane to smooth that top?Sycamore scrubs clean very well. It was the most widely used trad kitchen table-top material. Looks good too.
One of mine here:
Belt sander followed by random orbital.How did you sharpen the plane to smooth that top?
