Sheffield Tony
Ghost of the disenchanted
It is worth bearing the issue of nut allergies in mind when choosing an oil finish for treen. Some discount walnut and tung oil because of this, which leaves you with linseed (or rather, food grade flax oil) if you want something that will dry without risk of going rancid. Alternatively you can use a food grade mineral oil - Chestnut do one, or you can use liquid paraffin, which is the same stuff.
All of this is a bit academic as the board will still absorb whatever grease or oil that is in the food anyway. But at least if oiled to start with the greasy patch in the middle won't be so pbvious !
