Because it does not like it, the outside will be in tension whilst the inside will be under compression and there is a limit to how far the armour can accomodate these forces. It is not a major problem with SWA's upto 25 to 35mm CSA but once the cable uses shaped conductors then it becomes an issue for everyone.now a question, why cant you just put your foot on a bit of armoured cable and bend it as tight as you can,
