katellwood":18xjuxtu said:
Having browsed this thread has anyone considered the work of a woodturner at a lathe, would we consider his work to be machine made as it needs to be plugged in and switched on and only consider it to be hand made if produced on e.g. a pole or treddle lathe
My considered opinion is that even though a machine is required I believe this sort of work to be hand produced utilising the skill of the craftsman.
Woodturning, regardless of pole, treadle or motor powered lathe, is primarily by hand if the driving force behind the cutting tool is hand operated/powered.
By definition "handmade" literally means "made by hand rather than machine". So sayeth the Oxford English Dictionary.
Fell a tree by axe and you've felled it by hand, but fell it using a tree felling machine and it was machine felled under the guidance of a machine operator.
My point exactly, however it could still be open to conjecture. Would we consider a carver who uses a chainsaw or arbortech to create a wooden sculpture to be creating by hand or machine. I would suggest they could achieve the same or simliar result both with machines and hand tools but both would require artistic skill by the operator
My point is where do we draw the line. I consider this issue to be extremely subjective with no definitive answer (which is why I suppose this thread was started as a Poll)
A line is generally drawn at the point where manual input is superceded by mechanical input. Ergo the primary driving force behind the manipulation of the tool.
A steam engine is so-called because it is driven by pressurised steam, whilst a petrol engine is named as such because it's driven by the internal combustion of petrol. Both are named after their primary driving forces (The driver takes a back seat in this instance) and the same is typically the case regarding craft operations.
I could drill for oil in the North Sea using a drilling rig, but wouldn't be drilling the hole by hand........ The drilling rig would do that for me whilst I supervised it's operation.
Dig a trench by hand - using a pick-axe, trenching spade and shovel - and it's hand dug.
Dig a trench using a JCB and it's considered machine dug......regardless of it's driver/operator's presence.
Both arbortech and chainsaw are considered mechanical tools, with one specific to carving and the other to tree felling. Both are manipulated by hand, in spite of being either electrically driven or two stroke petrol driven, but both are also replacements for hand tools and the end results are considered machine cut.
Had Michaelangelo Buonnaroti carved a timber version of David using an arbortech, it would still have been considered machine cut and not hand carved, as the artist would have been the tool's operator and not the sculptor manipulating mallet/maul, pitching tool, point and scutch.
I think OED pretty well summed up the definition of the term "hand made" as quoted in my previous post. Artistry or no, if the primary driving force behind a given operation is manual, it is generally accepted as being hand made or manually produced, but if the primary driving force is via machine it's then normally accepted as being machine made or produced by machine.
It's a black and white either/or situation with minimal grey area betwixt the two (There's always going to be a marginal degree of overlap), unless one attempts to re-invent/over analyse/over phylosophise already standardised phrases and concepts.
