Anyone like a challenge.....?
woody67
24 May 2007
Cumbria
I'm not too bad with the Queen's English, but when it comes to maths............ :roll: So I would greatly appreciate if some good fellows could furnish me with a cutting list for the attached - approx w140cm, d60cm, h130cm.
I've been asked to construct something similar for the in-laws b&b business and said I'd price up the lumber :oops: unbeknownst to them I haven't a clue :oops:. Shop bought pine boards are the best option at the mo. Thank you and all comments, good or bad (more likely :shock:) will be appreciated.
Thank you
Mark
Although it's made out of pine, it looks like a nice peace of furniture to make. Your asking for a cutting list, well from the pic the main carcass thickness looks quite thin, about 10mm / 12mm maybe a little more (15mm). You know the depth 300mm approx, so you may have to glue 2* 150mm * 15mm boards together. So (keep with me here) Wake up at the back. So you know the out side dimensions, plus shelves, back braces, floor. The back panel you could use say 6mm ply. The door stiles, rails and draw fronts from 20mm thickness. The draw sides and backs use 10mm or so. I'm not doing all the work for you, there would be no fun left in it for you. So I hope that this has given you a direction to what I would work it out to. Oh and I normally add 10% onto material list. I have in my mind a guestimate to material price and labour. If you want to find out I will pm if you want.
