No, because on the second pass the bearing would be running on a curved surface and you'll end up with at least a bad witness mark which needs a lot of sanding out. As for suppliers, if you need one of these cutters Wealden Tool do a range of bull nose cutters (or as they like to call them "Bead and Edge Radius") which can take a guide bearing if required. Next day service, too. I sometimes use the 25mm and 32mm radius cutters for counter edges and they perform well in a router table.RILEY":2ddbtp1l said:I was looking at that exact same page a few weeks ago.
Couldn't the same be achieved with a roundover, flipping the workpiece for each side?
This picture from the Lee Valley site should make it clear:dickm":3pyw34uj said:Sorry to be stoopid, but how does that cutter accommodate "variable widths"?
For your application that might work out rather well, however for tasks such as stair nosings, countertop edges, etc in hardwood sanding out consistently might be impossible or just too time consuming.RILEY":1d2uvzoj said:FFC, I would always sand down after routing anyway, and as for the bearing running on a curved surface, I wouldn't use a cutter whose diameter matched or exceeded the thickness of the handle anyway, so there would always be a slight 'flat' for the bearing to run on, albeit small.
