Steve Blackdog
Hi folks,
Due to the laziness of successive decorators, one of my window frames has a fair bit of rot which needs dealing with.
I don't really want to cut the rot out and fill it - as that has been done before and the rot just carried on rotting, but under the filler (hammer) (hammer)
I'd rather cut back the rotten parts of the frame and splice in some new wood.
The frame is very simple Arts and Crafts/Shaker style - no moulding, just square sections.
The reason I don't want to replace the window is that they are old leaded lights in steel frames. The two side panels are fixed and were screwed to the frame before being glazed - they cannot be removed without trashing them. There is a centre panel is an opening window, which can be removed without damage.
The window has four vertical posts - one at each side and one between each pane, and one 'lintel' and one sill. The side vertical posts have rot next to the brickwork as has the top lintel. I think I will replace the sill completely.
Has anyone ever attempted this type of repair whilst the frame is in situ? I could do with any tips before I set loose on the project.
My current planned method of cutting out rot on the two edge posts is to rig up a guide and cut a slice the post top to bottom about 1" form the edge with a circular saw and dig out 1" deep with a chisel - maybe cleaning up the bottom of the cut with the router (a bit tricky though!). That would get rid of all of the rot (I hope). I suspect there is a much more sensible way to do this. :?: :?:
I keep putting this job off, but I can't put it off forever.
All ideas and experience very welcome.
All the best.
Steve
All the best.
Steve
