A spray gun by Clarks is likely to be rubbish, as its costing 20 quid,
I’ve used a £20 gun and it’s far from rubbish, though there are no parts available so once it gets worn out it’s dead.
Would have thought a fair indicator. But if it helps. Its to be paired with a Fuji minimite 3
That makes a huge difference and restricts any information I have as it’s a 3 stage turbine HVLP system with some unusual features.
not a category
unlikely to perform well as they require a 4~5 stage turbine (I use a compressor and a 4mm tip, but airless is the way for that and if you are doing much they cost thousands)
No idea why there is a 2 pack shellac as CH3OH (Methanol) has worked for hundreds of years as a solvent. But anyway a small tip works as it should be very thin
The same answer as for shellac
But the basic fuji gun doesnt come with 3 needles/caps, and just for that from them add a few hundred quid more.
my experience with spraying doesn’t include a turbine but does include several different guns, caps, tips and needles
The general guidance is that you need the smallest (usually about a 0.8mm) for shellac and other thin finishes a larger one (probably about 1.8mm) for most others and a huge (probably 4.0mm) for latex
you should be able to thin the finish enough for it to work with those combinations.
I have got several different tip sizes than the ones mentioned but really don’t need them, their usefulness is in using finishes thinned for them.
So my opinion is that unless you are putting a lot finish through the gun multiple tip sizes are not worth spending a lot of money on.
The most useful addition to my spraying is the pressure pot as it means that you don’t have anything restricting the angle or orientation of the spray gun. Though for it to be most useful I need to put a lot of finish through it to justify the cleaning time and wasted finish required. This of course is irrelevant to you since you have a turbine.
