tekno.mage
I've found a small Burgess three-wheel bandsaw lurking in the back of the barn. It was in a bit of a state, but the motor works and there are a number of fences, jigs and fittings for it and a new blade. I'm planning on setting it up with a fine-ish narrow blade and using it for small work, to save swapping blades over all the time on the larger Kity bandsaw which we normally use for ripping logs.
Trouble is, the table and fences are cast aluminium and have suffered from that horrible corrosion that affects old aluminium so consequently nothing moves freely.
Anyone know of a quicker (ie chemical) way than mechanical scrubbing or abrading to remove this? I've tried various kitchen/bathroom type cleaners and vinegar, but rubbing with a copper pan scourer had more effect than any of them!! Unfortunately the top of the table is of a ridged design, so cleaning it all up will take an awful lot of rubbing with the scourer :-( I'm also concerned about scratching it up too much, I'd like it to end up nice and smooth and polished so the wood slides over it easily.
tekno.mage
tekno.mage
