Mel769":1cvknppi said:It could be the type of breaker; motor start up current is usually higher than the running current; a domestic house type breaker is not designed for these startup current spikes. Its likely you can find a suitable breaker to fit your board thou; think theyr'e type C or B breakers or something. Alternatively it could be you have a fault at the fan or its circuit.
RogerS":1aqb1gp6 said:Mel769":1aqb1gp6 said:It could be the type of breaker; motor start up current is usually higher than the running current; a domestic house type breaker is not designed for these startup current spikes. Its likely you can find a suitable breaker to fit your board thou; think theyr'e type C or B breakers or something. Alternatively it could be you have a fault at the fan or its circuit.
No, it is not a breaker in his case. He said that it has been working for ten years.
As Argus has said, most likely the capacitor.
Mel769":2usp3mqg said:RogerS":2usp3mqg said:Mel769":2usp3mqg said:It could be the type of breaker; motor start up current is usually higher than the running current; a domestic house type breaker is not designed for these startup current spikes. Its likely you can find a suitable breaker to fit your board thou; think theyr'e type C or B breakers or something. Alternatively it could be you have a fault at the fan or its circuit.
Could be a faulty breaker, if the fan is on a separate circuit
