nev
Joy of joys! Low water pressure due to leak on shared supply somewhere under terrace of houses. Only solution is to run new supply from pavement at front of house, and yep! you've guessed, all plumbing is at rear of house and ground floor in extensions.
I'm not going to be digging up floors and running it up into floor space and back down again as that only covers half the distance anyway. So its surface mount. Straightish run along hallway through bottom stair and cupboard through original exterior wall and around kitchen wall to pick up nearest cold supply at washing machine.
Question: Is the copper going to sweat, if so enough to worry about? dripping/staining? Should I use P-EX ? Other solutions?
Thanks in advance.
Thanks in advance.
