Hi all you wonderful people!
I'm currently busy building my own CNC machine but have had many snags along the way which means I sadly haven't had a chance to complete it.
I'm hoping one of the many amazing people on here would be keen to help me with an experimental project that requires engraving with a CNC machine. Of course I will provide the end mills as required.
The Project:
The concept is an aluminium plate with a diameter of 420mm maximum (actual project area maximum 380mm) plate which I would like to engrave a photo of my partner and her kids on.
Using the plate the idea is to place it on the substrate then heat it up to burn the negative image onto a piece of wood. Due to the intricacy of the image, making a template to use in a pyrography capacity makes it unachievable. Hence the conclusion of making a template to heat up therefore transferring the image to the substrate.
Conclusion:
This is of course a prototype, which I have never attempted but I'm sure others have so any and all help would of course be greatly appreciated.
This would ideally be a Christmas gift for my "manager" (wink wink lol) as it would have great sentimental value for her.
The skills I would need to gain (& understand) is converting an image into vectors and then converting them to Gcode (or whichever platform required)
Appreciation:
From the above, I can mainly just thank everyone, but in turn will post a build process (including royalties/mentions for everyone involved.
I also will want to include a "snag" list so anyone who would like to build this project can & will have some tips overall.
All in all, I believe this project will be fun for anyone attempting it!
Thank you all in advance!
Best Regards,
Andy
The Project:
Conclusion:
Appreciation:
Best Regards,
Andy
