I have a air compressor that is about to get thrown out! Lol..
Just wondering if anyone has come across this problem
- Model
Airmaster Tiger 8/35
- Problem
Reaches 8bar then releases air till 6bar then just keeps cycling the same process untill the thermal switch cuts and stops it.
- so far
I've replaced the capacitor, parts of the pressure release valve (due to ebay knock off), cleaned head and piston valve, checked for leaks, none found.
It releases air from the small pipe into pressure release valve not the safety release valve.
I know there not expensive I just didn't mind tinkering about with it
But at this rate its going to be like 'Triggers Broom' hahahaha
Any advice or experience will be greatly appreciated. Thank you kindly.
- Model
- Problem
- so far
