I am wondering about the best method to repair a door frame where the hinge recesses have been drilled out far too many times. They have had previous dowel insert repairs and the door frame has split through the screw holes. The door frame is quite substantial and embedded in the wall of an old building so replacement of the whole thing is not really an option. It is at least 10cm x 5cm in cross section. The door is a large solid wooden door that weighs a lot, and was previously only supported with two hinges that have predictably become damaged, causing the door to drop.
Would a possible solution be to cut out sections of the door frame around the hinge recesses and splice in a new block of wood, into which a new hinge recess could be made that will better hold screws for the hinges? This could be done with a slight wedge at either end so that the inserts cannot pull out of the door frame with the weight of the door pulling on the hinges.
If such a repair is an option, what type of wood is advised? The door frame appears to be made of a high quality, quite dense softwood. Would a hardwood insert work to provide a strong new hinge recess, or should a softwood or near identical wood type be used? The door frame is painted so matching the grain is not important.
Many thanks for any answers/advice.
