Graham Orm
Beautiful
custard":2pwxdyr4 said:Very nice, I particularly like the way the curve on the heel of the saw plate blends into the handle.
IMO the counterbored nuts are much, much nicer than having them proud. If the nuts were engraved or cast medallions then it would be different, but plain nuts just look out of place left proud, and a discrete counterbored treatment gives a more professional and elegant appearance.
swagman":2h9ijg1c said:Today I was able to track down the quality issue with the saw bolt holes. While waiting for some 3/16 stainless rod to arrive in the post I was using the counterbore with the drill bit upside down as the pilot. Well the stainless rod arrived in the post today but before I changed out the upside down bit I tested it and sure enough the spiral cutting flutes clamped within the drill chuck was causing the counterbore to operate slightly out of concentric. After fitting the stainless rod as pilot the counterbore ran perfectly true. I tried this out on the new jarrah handle I have been working on and the fit around the saw bolt heads was much more tighter. Very pleased now.
