Another ***** question: dust extractors in series?
Deadeye
21 Aug 2017
Buckinghamshire
This woodworking thing is fun, but hard if you're teaching yourself.
I built a cyclone - which works really well. It's attached to an 850m3/hr extractor (basic Axminster one).
Question 1. I have positioned the extractor downstream of the cyclone, so that it handles clean air. Is there a reason not to do this (normally the chips and dust go through the machine and into a bag)?
Question 2. It handles bandsaw, tablesaw and router table really well (yes, I went shopping). It finds the planer/thicknesser harder to keep up with. By that I mean some shavings end up on the floor; blockages haven't been a problem. I use blast gates at each machine. I have been offered a second, similar spec, extractor. Could I add it in series, perhaps close to the P/thicknesser? Or is that a daft idea and I need to buy a new one with double the airflow?
For what it's worth, it's all 100mm, except the router table steps down to 60mm.
thanks
You need to match the extractor to the machine’s stated requirement. It is unlikely that a Planer/thicknesser only requires 850m3/hr extraction. Most require about 3 to 4 times that level of extraction.
As for the rest read Siggy7’s extraction thread.
Pointless having a cyclone after the extractor - the purpose of a cyclone is to capture the chips before they get to your extractor, as it's easier to change the cyclone bin than it is to change the extractor bag / clean the filter.
As for running then in series, I read somewhere that you can do this and see a small improvement, but not as much as just upgrading the extractor you have to a 2hp or more
You've positioned the cyclone correctly, I've never seen someone with a cyclone after the extractor.
If you're struggling for airflow, my advice would be to sell on your current extractor and upgrade to a single bigger unit. I would have thought having extractors in parallel rather than series would give better performance if you wanted to add a second unit instead, but you would need to take care to balance performance of the two (e.g. two identical units with a similar length of inlet hose to a common y-piece).
Having extractors in parallel means that one impeller will starve the other
