I attended a 'get together' and sharpening demo put together by the ubeaut wood working forum.
This alternative method of sharpening bears consideration, especially if you already have a bench grinder.
I watched a member (Matt) on another forum take a cheap generic chisel with its machine marks and poor finish and take it to a mirror polished and wickedly sharp state in about 5 to 10 minutes with this setup.
Very quick and no fuss.
Matt is a cabinet maker with 20+ years experience, and likes to have the sharpest edge, most efficently reached, on his edge tools.
Mount a 6", or so, disk of timber or MDF (about an inch thick) to a bench grinder. Use rouge on the disk and polish the back and the micro bevel. Very quick. Use the side of the disk, and ensure that you use the bottom half of the disk so that you don't have the disk throw the chisel at you. Wipe water on the disk when it is spinning to stop the rouge from sticking to the tool.
The tool is finished with a few strokes each on a 1000 and 6000 grit stone, then a quick buff on a narrow buffing wheel loaded with rouge. (Matt used about 10 - 15 strokes on each grit)
Buff for a few seconds, until you cannot feel any irregularities on edge when you run your fingernail across the edge.
After use blunts the tool, the edges are 'touched up' on the buffing wheel until the edge tells you to go back to the 6000 grit.... eventually the bevel will need the 1000 grit and so on until the bevel is so large regrinding is needed.
My first attemps at including photos :roll: :
http://www.woodworkforums.ubeaut.com.au ... 1156466913 Disk in use.
http://www.woodworkforums.ubeaut.com.au ... 1156466875 - a complete set up.
Further pics on page 5 of this thread:
http://www.woodworkforums.ubeaut.com.au ... 324&page=5
A video will be put on the ubeaut forum in a week or so, just search "videos + Gumby".
