American Black Walnut Smokers Bow.
merlin
7 Nov 2010
Oxfordshire
Firstly I would like to thank Sheffield Tony for inspiring me to make this chair in the first place, I was asked to make a chair and after reading his post it made my mind up for me.
American Black Walnut was the colour that I wanted so I selected some sizes that suited, I had to join the seat as nothing was wide enough but the legs etc. were all ok.
I decided to machine and construct a trial chair first out of off cuts as the timber was quite expensive and I didn't want any mistakes plus I wanted to put in a few different features of my own.
Jack Hills design was the starting point and very useful but I soon realised as Tony did that some of the angles were a bit out.
I made up a seat out of joined 9x1 par and had my first attempt at hollowing the seat using a gouge, this proved hard work so I bought a Veritas Pull shave and a Windsor chairs Travisher, they were both fantastic tools to use and gave great results.
I joined the Walnut seat and hollowed it out using the new tools and it was much easier, I finished it off with a Random orbital sander being careful not to loose the sharp edges.
Next was cutting and finishing the arm bow, I dowelled the 2 halves together as I found it easier to drill the spindle holes without the back scroll fitted
With the holes drilled (using a pillar drill and hinged table) I fitted the back scroll and rounded off the edges etc.
Then for something I haven't attempted before.... carving. I followed the Chris Pye book and once it was marked out and a trial piece completed I didn't find it too difficult but I must get some proper carving chisels.
The turning was all straight forward once I had decided on the actual shapes.
Then to drill the seat, straight forward again but because I had made a trial chair it showed me that the angles in the book were a bit out so easily remedied.
The Portcullis was a bit more difficult but as it was not fixed to much, the wood part was ok but welding the chain and the rings was a bit more of a challenge. Once the main parts were completed it had to be fixed together and mounted to the back.
At last it was a case of putting it all together and finishing, the finish was Satin Osmo Polyx oil and I was pleased with the end result.
I sanded the chair down with 600 wet and dry before the first coat, the tin recommends to not go that fine but I didn't like the scratches with the 240/320.
After a day I again went with the 600 and gave it a tickle with some wire wool and then the top coat. After some advice and research from the other thread I decided 2 coats were enough particularly as it was a present for the next day!
Merlin
    105.3 KB
    112.8 KB
    119.4 KB
    137.9 KB
    100.1 KB
    115.3 KB
    100.9 KB
    122.4 KB
    160.8 KB
    162.5 KB
Excellent. Thanks for posting the pictures. The carving looks good to me; the only letter carving I've done was a clock, and I chose Roman numerals to avoid the curved bits :oops:
What will you do with the spare chair now ? Workshop chair ?
Another project on these boards that fills me with skill envy! Well done that looks amazing!!
Thanks for showing us a bit more - it's a really impressive piece of work.
One feature I really like is the way the ends of the arms mirror each other for grain pattern. In retrospect I can see that happens automatically if you cut them as a mirror pair from one wide board. Did you know that in advance? Is it a thing that chair makers know?
Thanks Gents, the softwood model is going to be the workshop chair for those "ponder moments" and poor old Mr Trump isn't getting a look in.
The arms will all depending on grain mirror each other, it is a matter of getting as much out of the plank as possible and it looking nice.
I haven't really made a chair before as it has always looked like the dark art but doing it the "bite size chunk" route I think most things are possible, at the end of the day all this wood working thing is -
is cutting wood but in a different way.
Merlin
Thanks very much gents.
I hadn't done much of this kind of thing before so it just goes to show - bite size chunks and most things can be done.
Its all only cutting wood but in a different way.
Merlin
