mailee":1yopn859 said:How on earth are the first ones attached to the walls? :? I have seen the book case ones before. As Bob says none of them meet the regs though. :roll:
angelboy":7pxhtrfo said:I want the one with the slide for our house!
Karl":ofhnp8mh said:I think (although am happy to be corrected) that if you can prove that this isn't the prime staircase in the house (ie there is another primary use staircase which meets the regs), then the regs don't apply to the secondary staircase.
But I may have just heard that somewhere and it's nonsense. :duno:
Karl
angelboy":yfzwbqhs said:mailee":yfzwbqhs said:How on earth are the first ones attached to the walls? :? I have seen the book case ones before. As Bob says none of them meet the regs though. :roll:
I'm sure I've seen something like this before. They'll have steel rods fixed through the wall (probably bolted against steel plates) for the timber treads to slip over.
"You're about as useful as a one-legged man at an arse kicking contest." - Rowan Atkinson. :|
Benchwayze":2jqydgta said:I followed the 'stairporn' link.
John 8)
chippy1970":ggmz32mn said:Benchwayze":ggmz32mn said:I followed the 'stairporn' link.
John 8)
You liked it then
Good find eh ?
