Here's the Stan 4 1/2 then. I couldn't wait for the Liogiers so struggled on the tote with nasty old machined rasps etc.
Spent the first while tuning til I was happy it actually worked OK, only then would I spend time on a knob and tote. But it works well - the blade is a nice laminate, cap seating very well, frog well-bedded etc. Sole was near flat but a tads high at toe, so got lapped, It's set-up as a smoother with slight camber, but can take 15 thou shavings happily (it's hard work though, a calorie burner):
The knob is cherry from a large branch, hence knotty - but well seasoned and has character. The tote is cherry, off the end of a board and a bit wild. The grain works in favour of the tote shape though (note the grain flow over the top, where they usually break):
And here it is actually working for a living - flatting a 6 x 2 ash board 7 feet long:
Have to say I like it, and I am impressed with it's build and performance. I can't say it's better than the Record SS as I don't think it is. And I rate the SS blade assembly for stiffness. But it is rather good. They can be picked up very cheaply - recommended if you want a quality bargain and are happy doing a bit of tuning. The knob and tote work is obviously not necessary, but it sure looks pretty
