alternative to castors
skeetstar
7 Sep 2014
southam, warwickshire
Folks I am making a moveable reception desk. I plan to use castors and set them in such a way that they will be virtually invisible by being shrouded by timber which will reach to within a few millimetres of the floor. All well and good, but I need a way to immobilise the desk when in use. I can't use locking castors, since their use would be restricted due to their position and being largely behind timber.
I reckon I can solve the problem by some sort of device that lifts the back end on a rubber foot or somesuch.. picture refers. I have done loads of serches but cannot find anything suitable, what I can find are lever operated door stops. but but the look of them (and the prices) they wont be substantial enough to take the weight.
Anyone know what I am looking for ? Or suggest an alternative?
Thanks all
    63.6 KB
I had exactly this problem some years ago. The item was a kitchen unit which needed to be mobile but firmly placed when used. The solution was to mount the castors on a platform then attach the unit to the platform via a linkage mechanism which could raise and lower the unit.
My original concept was that it would be operated by a lever on the side of the unit. However my client had more ambitious plan. He decided to electrify the system using a motor to drive a lead screw which activated the raise/lower links. He was the ideal man to do this as he was an engineer working for a firm that made mechanisms for disabled people.
It all worked well with the unit being mobilised at the push of a button.
It's a pity I haven't got any pics.
Brian
I dont know if you have the space, but did you consider something like Carl Holmgren's
lifting mechanisms?
I made one for my startrite tablesaw where the casters are inside the cabinet.
Or engineer a couple of sliding legs actuated by a cam with a handle long enough to give plenty of leverage to jack the whole desk up? Using hardwood offcuts the only expense would be the fixing/pivot bolts for the cams.
Thanks to all who have taken the time to reply, I will ring a couple of those
suppliers this morning, there is one castor that looks promising.
