• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
ALDI Ferrex Recipro Blades.
KraftyKev
19 Nov 2022
Northants
Just thought I'd give a heads up.
Not used them yet but picked up a pack of Ferrex Recipricating saw blades today in Aldi.
£7.99 iifc
Product Information
Ferrex
  • A set of 12 Reciprocating Saw Blades - ideal for cutting through metal, wood and PVC. This set includes 3 for Metal (150mm 24 TPI), 3 for Wood (150mm 6 TPI), 3 for Wood (150mm 10 TPI) and 3 for Wood (228mm 10 TPI) (TPI = Teeth Per Inch).
Contents
  • 1 Piece 1/2“ universal shaft suitable for most sabre saws
  • 3 x Wood saw blades (material: CRV, HRC45-55°, length: 152mm, width: 19mm, blade thickness: 1.2mm, 6 TPI)
  • 3 x Wood saw blades (material: CRV, HRC45-55°, length: 152mm, width: 19mm, blade thickness: 1.2mm, 10 TPI)
  • 3 x Wood saw blades (material: CRV, HRC45-55°, length: 230mm, width: 19mm, blade thickness: 1.2mm, 10 TPI)
  • 3 x Metal saw blades (material: body: bi-metal 6150, HRC26-35°, teeth: HSS, HRC58-65°, length: 150mm, width: 16mm, blade thickness: 1.0mm, 24TPI)
  • 1 x Extending plastic storage box
Suitable For:- Metal, wood, PVC
Have a couple of boxes of these, work fine in wood and plastic but they do dull pretty quickly. I would have thought the so called metal cutting blades are too coarse to be of much use, but never actually tried them on metal. Very cheap, so good for jobs where you know the blade is going to have a hard time, tree roots etc, and you dont want to ruin a good one.
