I've made a wooden lid out of 18mm moisture resistant MDF.
It has been painted with multiple layers of Plastikote aerosol primer and sanded so it's perfectly smooth.
I've moved on to Plastikote aerosol satin wood paint and I want the finish to be perfect like on a car. I've used multiple coats and it's looking patchy. I tried up and down, side to side from one end to the other. I also experimented with slightly different thickness layers.
There were a few areas that weren't flat so I used 320 and 360 grit wet sandpaper to sort it out but there are light scratch marks (nothing more than surface deep). When I sanded it, there were clumps of paint being picked up from light wet sanding.
The paint is still flat but patchy.
Can I sand or should I not do that? Why is it patchy and how can I get that perfect finish that is totally flat like on a car? I've used about three cans of satin wood on it already (it's about 1m X 0.40m).
Any experts out there?
