graduate_owner
Hi everyone,
I've been looking at pin chucks on the web and they seem so easy to make that I thought I'd have a go. So I found a straight piece of 16mm diameter steel and milled a flat about 1" long, about 1/2" from the end of the bar. I then cut a piece of round nail of suitable diameter (about 3.5mm) and mounted it in my 3 jaw chuck. When I checked it with a dti there was about 0.3mm run out. I tried re-mounting it a few times but couldn't get the run out much less. I then checked the lathe spindle and the run out was about .02mm so I suppose the inaccuracy is with the chuck. Just to make sure I chucked some more items, drill shanks etc and the run out was still the same. I tried re-assembling the jaws but still no improvement.
Anyhow I thought I'd try it to see how it performed, so I drilled a 16mm hole in a log of about 6" diameter and mounted it on the chuck, with tailstock support. It soon started slipping under load, so I tried a larger nail diameter. This held, but after turning the log to round I was getting noticeable vibration. I removed the tailstock support just to see how well the chuck was holding, and the log started to make its way off the chuck without any tool contact. I removed the log and could see the pin chuck was now a very loose fit in the hole.
SO, what I'd like to find out from you experienced guys is:-
1. when you use a pin chuck, do you get any vibration after turning to round?
2,. do you have any idea of the run out of your set-ups, or any idea of what is acceptable?
3. does your wood become slack on the pin chuck after being turned for a while?
4. how tight is your pin chuck into the hole - do you drill the hole slightly undersized to compensate for 'wear'
5. do you have any ideas on what else may be going on with my set-up?
Any ideas / advice etc would be much appreciated.
In the meantime it's back to the drawing board, or perhaps a bigger nail in the chuck first!!
K
K
