graduate_owner
Hi all, here's another request for advice. I bought a Yorkleen WV1, blue - so I think it is quite old, although seems to be working fine. My question is regarding the filters. Yorkleen have told me there should be three filters, a cloth filter around the wire cage which surrounds the motor, a paper filter around that, and a cloth drum filter. Well I only have the motor filter, but it is obvious where the paper filters go. What I can't visualise is the cloth drum filter.
Do I need one? If so, where does it fit? I haven't seen one so can't get my head around it. If it traps the coarse dust, what is the point of the plastic sack?
Also there is a small pipe, about 3/4" diameter running fom the inlet rown to the base. I assume this provides some vacuum to the bottom of the collection sack to stop it from being sucked up towards the motor. Is this original, or someone's modification.
The other puzzler is, there is a metal grille with about 2" squares between the wires. Where does that go? If I put it in the base of the collection sack to weight it down it will be covered in waste and will need to be retrieved each time the sack is emptied, so that doesn't seem sensible. Or does it just sit in the base to keep the sack clear of the 3/4" pipe? Or is it an addition, again someone's modification?
Totally confused, as I'm sure you can see. I know it sounds a bit daft but, as I said, I haven't seen the original set up.
Can anyone clarify things for me?
K
K
