Hi All
I've read through most of the very interesting workshop build threads here, found answers to a lot of my own questions and plenty of food for thought. I'd like to share my proposed project with you for comment, advice or suggestions. I have a very small suburban back garden, approx. 40 x 40. The largest shed I can build is 20' x 12', and this to be subdivided to create a dedicated 12' x 5' space for the garden tools, bikes etc- not generous I know and before i even start I know this shed is too small! But it's the space I have and to me it represents a lifetime's ambition to have a purpose built "man-cave" like I propose.
I need something pretty quickly, with minimum disturbance and mess so I've decided to go down the insulated metal clad route. I've looked around and the option I really want is of course the most expensive- 20 x 12', 7' high at eaves rising to 9' at the apex. Kingspan 60mm panels, roof and walls, 4 polycarbonate clear lights (rooflights) and 2 double glazed windows to the workshop area (14' 6" x 12'). Insulated steel door to the "garden shed" part and insulated steel door with 10 point locking to the workshop part. Concrete base will be insulated (50mm kingspan) and I'll incorporate a duct for a permanent electrical supply. I propose to ply line the full interior (except roof of course) in 1/2" and 3/4" shuttering grade ply. I'll use the 1/2" ply on window walls where there won't be much hanging off them anyway, elsewhere I'll use 3/4" for hanging ability. I won't stud out but glue fixing battens/ firring strips as required to cladding rails etc with panel adhesive. I'll avoid puncturing the cladding panels or structural elements where possible. All electrics will be surface mounted- probably plastic. Security wise the 10 point door is solid as **** and I have no worries with it. I'll get a couple of window grilles fabricated for the interior of the windows- I have two old roller blinds that can be cut down to suit. I'm going to use a cheap floor paint on the floor (powerfloated I think) and place rubber matting at the two work benches to save my chisels! I plan on using an oil filled rad for intermittent heating, it shouldn't cost a lot to run and keep the dreaded rust at bay.
I looked at just getting a cheaper uninsulated shed and studding it out myself, insulating etc but the cost of materials alone was eye watering and there is a lot of potential for interstitial condensation and mould issues if not done correctly. I need to keep the building height on the low side (I'm not tall anyway) to keep within planning restrictions and so as not to upset my neighbour. This is a once-off project for me, I have to compromise on size but I don't want to compromise on quality or comfort. The fun part of this build for me is fitting out the workshop, building the storage and organising it as best I can- my dear wife has sanctioned the build cost of my "Rolls Royce" option so I can hardly refuse ; )
What do ye think?
What do ye think?
