Lightweeder
I need to invest in some large chuck jaws - the type with rubber feet - for holding bowls while working on the base. I assume most will fit into my scroll chuck. Is there one that you guys can recommend please ?
If you want to save the expense you could reverse chuck and use the tail stock for support. This allows you to turn away most of the chucking point and then hand carve away the final tail stock support area. This is what I tend to do.
Duncan
Lightweeder":3j4u95wm said:but he just manages to get his centred first time :? :? Mine are never out much, but enough.
loz":32taphil said:Lightweeder":32taphil said:but he just manages to get his centred first time :? :? Mine are never out much, but enough.
hiya !
Are you marking a centre dimple when you create your chuck point,?
this is then used when you reverse back to centre up with ( put the bowl base and dimple against the tail, then slide up the tail towards your jam )
It will be damn close enough if you do this.
