Thanks for that.
Ive not tried the latest blum or grass -the last time I was using Hettich 4d V6 runners.
I will get some blum runners and give them a go.
Yes sometimes, I like their stuff.Nobody using Hettich
Always found they functioned better hung seperately with the corner post attached to oneFor the corner unit....I put shelves in the corner cupboards like in any other, but hinge the two adjoining doors to each other so that they operate somewhat like a bi-fold. This means when they are open you have a huge opening to get at the cupboard contents, for the grand cost of a couple of hinges. Obviously, this means an L-shaped unit without a corner post or central divide.
Usually called light pelmet SteveSo get a stick, place it bwteen the worktop front edge and the underside of the cabinets, touching the plinth (or whatever that bit of trim is called that is fitted underneath
