haf63
I recently came across this site and its amazing. I have read through a number of projects as part of my research and feel i have a good grasp of the fundamentals so hopefully won't ask too many 'basic' questions.
I am fairly familiar with building/planning as have done both a small extension and project managed a large one so understand most of the trades and regulations.
The attached file shows a top view on the left showing the shed within 1m of the fence and an irregular shape.
On the right top you can see a side view showing single slope roof
On the right bottom an example of what i think is the right solution for me
So my thinking so far
- I don't think i need planning as its less than 30m and max height is 2.5m
- I don't think I need building regs but will need an electrical cert
- I am unsure on brick or block render or wood but leaning towards wood
- I think i 2 options on fire safe cladding so cement board or composite but not sure which is better or costs delta's
- I will have to go with a flat roof design to maximise space given 2.5m limit - but not sure exactly what kind of flat roof yet.
Any comments/advice appreciated as I am a the early stage so can change pretty much anything
Budget is a concern but don't have a max figure - ideally 5k but can go a bit higher
I will be doing pretty much everything myself or with a few friends in the building trade
