All
I am currently designing/planning the construction of two lots of cupboards and shelves, plus a desk, to fit into the alcoves either side of the chimney breast in our dining room. Current design looks like this:
Each alcove is approximately 2.6m high by 1.3m wide and the desk extends 1.7m from the far wall.
I would greatly appreciate any observations, suggestions or even criticism (hopefully constructive) of the design and/or proposed construction method.
Carcass, shelves and desk all to be made from 50mm thick honeycomb boards (torsion box style) using either 6 or 9mm MDF skins with the core filled with 32 or 38mm cardboard honeycomb such as this. This will form a torsion box like this (pic from Dufaylite):
I propose to add framing around the edges and internally where needed e.g. hinge recesses in cupboards. From my research so far the framing materials suggested are MDF, Chipboard, OSB and timber (soft or hardwood). Requirements for such a material are that it should be stable (no twisting/shrinkage), 'glueable' and accept drilling/machining (dowels, biscuits, hinge holes/screws etc) and available in necessary dimensions e.g. 38mm if 2 x 9mm skins used. Finish will be paint - possibly high gloss white. All fixings/joins to be hidden/invisible. I'm a reasonably competent DIYer but this is all new to me so would welcome feedback, particularly on:
1) best framing material: for ease I could use say 2 x 15mm MDF which would give me 48mm (near enough to 50mm) overall thickness but am uncertain about screw holding strength. Chipboard -same concern and general aversion from past experience as a consumer. My preference, I think, is softwood as I can dimension it (P/T available), affordability etc but am uncertain as to its stability. Would kiln dried structural timber be OK e.g. 100mm x 50 nominal?
2) Cupboard doors: these will be flush with the carcass and minimal clearance desired for aesthetic reasons. Will 15mm MDF be robust enough or 18mm better? Two hinges per door which I'd like to be adjustable (up/down and in/out) - which type? Push-to-open catches - 1 per door? Again, any recommendations on manufacturer?
3) Joining: glued butt/mitre joints unlikely to be strong enough so some kind of mechanical fixing required. So I need to consider dowel versus biscuits (or splines) versus ?? Thoughts on pros and cons welcome. I do not currently have any dowel jig or machinery (Domino or other) so will acquire what's necessary.
4) Machinery: I have a bandsaw and C/S but neither is ideal for ripping boards with a straight edge, so am considering a track saw rather than a table saw, especially as my work space is limited (probably the dining room table!). Makita SP6000 ahead of the Festool 55/75 on value for money grounds. Am I thinking straight or will a (small) T/S also be needed?
Sorry, it's a long post but want to get the design finalised and my thinking straight before ordering stuff.
