Adjustable dado / housing joint jig
Charley
24 Aug 2002
Collingham
Want to create perfect dados without any fuss? Then you NEED this jig. It’s quick and easy to make and even easier to use….
Haven’t included any measurements as it can be made to pretty much any length (within reason) to suit your project. I made mine out of scrap I had in the workshop.
Great Stuff Charlie but I am a bit confused with few more mm added to the 65mm , do you have any measurements ?
Regards
Mick
Cheers, Mick. I don’t have the measurements here, I built it as I went along out of whatever scraps I had. I’ll measure it tomorrow and post the details.
For the guiderails, what you’re trying to achieve is to get the width of the guide-rail (from the edge of the fence) to the exact measurement of the edge of your router cutter to the edge of the router base.
So for example, if the router measurement is 65mm and the width of your fences are 30mm, add a couple of mm to that and cut your guide-rails 97mm wide. You’ll then end up with oversized guide-rails which you can trim to the exact width with the router once you’ve attached the fences.
