adjective
GEPPETTO
26 Oct 2004
Vinci (FI) - Italy
Hi all,
Naturally, because I am a foreign I must translate every word of your language. Often I find the term "mitre" which is translated in my dictionary like that thing which shoots. Therefore I do not Know to associate this term with "plane" or "saw" (mitre plane and mitre saw I think it is said in this way). Can anyone explain me (with simple words) the adjective in the world of woodworking?
Thanks in advance
Hi Geppeto
A mitre saw is one that cuts at angles (usually variable) such as 90, 45, 33.3 etc. Typically a powered saw like this:
http://www.diy.com/diy/jsp/bq/product/product.jsp?CATID=7920102&entryFlag=false&PRODID=203719
or one might prefer to cut by hand using a mitre box and hand saw like this
http://www.diy.com/diy/jsp/bq/product/product.jsp?CATID=6990009&entryFlag=false&PRODID=6820024
or this
http://www.trueshopping.co.uk/product.php?pid=22577&cid=190&rfid=5&pn=Sealey+Mitre+Saw+120mm
A mitre guide is the thing that slides along the track in a table saw, router table, bandsaw etc. and allows 90 degree cuts as well as adjustable angles
One can also shoot on a mitred shooting board where you would typically lay the plane on it's side and plane the end grain of a piece of wood to 45 degrees.
Hope this helps
Hello Geppeto,
A useful dictionary resource can be found at http://www.askoxford.com which gives access to the compact Oxford dictionary.
One of the definitions for mitre on this site is ".. a joint made between two pieces of wood or other material at an angle of 90°, in which the line of the join bisects this angle. "
Just to confuse matters, the americans use the spelling "miter" for the same thing!
Hope this helps.
Regards
David
(An alternative site is the Oxford Advance learners dictionary at http://www.oup.com/elt/oald/ which provides slightly simpler definitions. This defines mitre as " a corner joint, formed by two pieces of wood each cut at an angle, as in a picture frame")
Thanks to all,
Ok. Let us try to see if I have understood well:
I can understand that term is associated to the saw mitre, to do the angled junction, but I don't understand why the term is associated to a "HANDPLANE" ??
Perhaps it is because the junction could to be planed with a such plane on a angled shooting board. Is it true??
dedee":8gy512wy said:
Geppetto,
Indeed the mitre plane is intended to be used on its side on a shooting board eg
http://www.lie-nielsen.com/tool.html?id=9
By the way I hope you do not mind me pointing out but I think you mean "joint" when you say "junction".
Andy
I have been on a english dictionary online and I have undersood the difference between both terms.
Yes, I wanted to say "joint".
Thanks for the correction
