Adirondack Chair parts
wizer
3 Mar 2005
So how would I go about modeling this in sketchup? I have been trying to do it with pencil and a sheet of MDF but can't get it to look right.
I want to make templates of all the parts for the router.
Are there anymore images of that chair?
I might use PhotoMatch from that image but it would be tough to get it perfect because you don't have enough straight lines on axis. I would look for a 2D side view if it exists and import that. Then trace over it. Finally, you could wing it and start drawing from it, knowing some basic chair dimensions. I have a different Adirondack chair modelled on my home computer. I could send it to you to give you a starting point. Or I could get this one started for you if you want.
Cheers Dave. This is the only pic I can find. It was part of an FWW article. I have found loads of articles and free plans for Adirondack chairs but typically I (and SWMBO) like this one. This is where I found it. http://www.taunton.com/finewoodworking/ ... x?id=29041
I think, in this instance, I may be better off persevering with pencils. I drove 10miles to buy a flexible curve this afternoon. It would be interesting to see it in sketchup tho, I find viewing a model from all angles really helps visualise each part, joint, etc.
I did a bit of searching for images of that chair from other sources. No luck.
I think you could do as well in SU drawing it as with pencil and MDF but you might like to see it full size. I'd be inclined to try a mock up from some cheap stuff to work out the angles and so on. Knowing the height, you could probably scale out the rest.
I'll see if I can magage to get something for you in SU but I've got a couple of other jobs up first.
Thanks Dave. I just had a hunt on 3D Warehouse for Adirondack chairs and found some good examples. I'm going to see if I can work out how to adapt one to how I want it. If no luck then I'll resort to the pencils.
Been playing with this some more. I took an Adirondack chair I found on 3D Warehouse and have been modifying it to make it a bit more curvy and use slats all the way to the top.
Question is: Is there an easy way to do the slats in SU? At the moment I have just being copying (ctrl+click move) and then rotating it to the correct angle.
File hereif interested.
Hi Tom,
Sorry I didn't get back to you on this. I had all sorts of stuff blow up at home over the weekend. I think it's all sorted now.
Nice job on the chair. I think I have an idea about placing the slats but I'll need to play with it a bit, first. Headed to the dentist in a few minutes though so when I get home, I'll give it a shot.
Dave
Thanks Dave, no rush. I'm still fiddling with it's curvyness. Probably making more work for myself on the build. But I want it to look a little less clunky than the traditional Adirondack.
Here's what I ended up. I didn't fix the frame pieces, though. If anyone is interested, I'll work up a proper tutorial for placing the slats.
ah crap, you beat me into the ground there Dave ;)
Don't mind at all, eagerly await the cheque.. ;)
Thanks again Dave.
Dave, as ever, a great tutorial.
Do I understand correctly that the pathcopy script requires that you leave the original slat, even after it has been copied? Or have I misunderstood?
