UPDATE:
Thanks to Scrimper for the heads up, I had completely overlooked that the Hegners have induction motors. This speed control should NOT be used on anything that has an induction motor. Fine for things with normal brushed motors.
Hi All,
When I bought my Hegner earlier in the week it turned out that the "Variable Speed" was down to shocking wiring in the foot pedal.
Wasn't too bothered as I got the Hegner at a decent price but figured that as the Record had it maybe I would like it for cutting thinner material and also teaching my other half to use it.
Some of the offerings on the market are bloody expensive for what they are. Initially I started looking for circuit diagrams as I used to make these things over 20 years ago when I worked for a tool hire company, made the PCB's etc. Research led me to eBay where i found and SCR controlled voltage reg and duly ordered one.
It arrived this morning and after finishing the dust extraction project started on the speed control project, pulled out some bits from previous projects and began assembly.
The pictures below show the process, basically position speed controller hole for the potentiometer in the box with enough room to wire it. Mark the cable for feed and load, figure out the wiring (no diagram supplied) the Neutrals are commoned on the back of the board as it's always controlled on the live side. Normally the supply and load side would be obvious if you bought a speed controller with a plug and trailing socket. Out was marked on the board. Next step was crimping up the fly leads (i'll be hard wiring in series and getting rid of a load of excess cable and connections) Then connecting the cables to the controller. The Earths are just connected together.
Any questions let me know. Mods, please feel free to move, posted it in here first as it's probably most useful here and I have had a lot of help about the purchase of a Hegner SS.
This controller is rated at 2000W (2KW) I would not run it at that constantly, the Hegner is only 100W as are most scroll saws so well within it's capability
Pictures are here:
https://www.dropbox.com/sh/12lh0mzsi3ml ... Zzpca?dl=0
Cheers,
Jon.
Hi All,
Pictures are here:
Cheers,
Jon.
