PaddyR70
Hi
90% novice here. I’ve added a vice on the end of my woodworking bench using two tail vice screws. The price of buying a twin screw vice was too much for me. I’d like to add sprockets and chain to achieve the same thing having used it a while and realising the awkwardness of clamping some stock. They would be situated at the ends of the screws under the workbench.
I have no mill. I have a router table , bench drill, angle grinder. I can see 28mm bore keyed sprockets but none with just set screws. I could take them to a welder maybe? Use the bench drill to drill a series of connected holes and channel it that way? Grind / drill two flat zones for set screw sprockets? (If they exist?)
How would you guys tackle this?
Help much appreciated
