MikeG.":37g8jxwb said:Chris152":37g8jxwb said:Yep, if I'd checked the ply thickness before I'd started I could have made the runners for the plane the right height to work with the ply I already have.
Making up ply the right thickness is a good idea if I can find a source. That said, I have access to a decent thicknesser just up the road - is 4mm thick (x 50mm) thick enough to thickness down to on a machine or does it get tricky being thin? I've only ever used it on larger stock and no idea how it works with thinner pieces.
Yes, you'll be fine, but you'll need a false bed sitting on the bed of the machine. No machine will let the bed get that close otherwise. If you make one of these, you'll need a lip on the trailing edge to prevent the bed being pulled through the thicknesser when the work is fed in.
Check the thicknesser, some will go down to 4mm, the range on mine is specified as
Planing height: 3.2 - 152mm (I've made a few hundred louvre slats 5mm thick no problems without a false bed)
