3Quid
First post on the forum after much time spent reading. Hi!
The specific purpose for me buying a table saw is to produce wedges from oak boards that will be used in a lighting project I am doing. The focus for the work is accuracy over speed and/size. The finished workpieces will be fairly small (H 200mm, W 40mm D 50mm) and will be cut from boards ranging from approx 1.2m air-dried oak boards. I would also like that the saw be useful for various future tasks but this is my initial purpose for buying.
So, rightly or wrongly, I recently purchased an Axminster TS-200-2 based on reviews here and elsewhere. Budget is an issue at the moment so I saw this is as a machine that could get me up and running with a reasonable spec at a great price. I know you get what you pay for etc... but reality is I can't spend 1k+ on this right now (unfortunately!!).
Anyway, TS200 arrived. Bits missing, incorrect scale on fence rail, instructions detail steps for the TS250 in amongst the common steps without mention of it not applying to the TS200. Plus the machine had clearly been put together previously and no longer had it all its original packaging. Anyway, this isn't a tirade against Axminster. They delivered it promptly and have dealt with my issues quickly and politely. Short story, it's going back.
This leaves me with a problem - that being there aren't many options at this price. I'm pretty convinced that a cast iron table is something that should be at the top of my hit-list as accuracy is key. However, happy to be proved wrong.
So, budget increase! I am now looking at the Charnwood W619 £519 and the Xcalibur 10" Tilting Arbor £521 - sorry I can't post links.
I have a reasonable amount of space in my workshop but not vast. Budget-wise, the machines above are at the very top of my budget. I'm not against the idea of a used machine, but living in Cornwall, often secondhand stuff is so far away that the petrol/time costs and/or delivery/logistics rule them out.
I'm basically asking, based on the money I have and the tasks I need to perform, are these the best machines I can hope for (new)? If not, please could you suggest some alternative models?
As you can tell I'm quite new with all this so take it easy on me. Thanks for any help you can offer.
