markblue777
Hi All,
I am looking for someone who has a metal lathe or knows of a company in the Waltham Cross area (or close by) that could help me enlarge a hole in a sprocket hub holder. I am building a motor powered trike and I bought an axle assembly and realised after looking at it setup on my floor that the sprocket is too far over one side for the engine to mount correctly. So what I want to do is enlarge the existing sprocket hub so I can slide it further onto the main axle and then I can fix it in place in a better position.
I have done a search and cannot find anyone that can do it near by so far.
Failing that does anyone have any 28mm OD x 22mm ID (3mm thick wall) mild steel tubing, I need about 100 - 150mm in length
Mark
Mark
