The new Tormek stone is as below This innovation will help this type of heavier steel removal. It sell for £116.95 incl.
Tormek Blackstone Silicon SB-250
This is available only for the T-7 model (SB-250). It has been developed for hard materials and fast shaping. Its faster steel removal is an advantage especially when grinding tools with a large bevel surface, where the grinding pressure is limited, e.g. planer blades and woodturning skews. The SB-250 stone can also touch up tungsten carbide, which has an established shape. The grit is the same 220 as the original Tormek SG-250 stone. Its very sharp grains remove steel efficiently in spite of their relatively small size. Like the SG-250 stone, the SB-250 can be graded with the Stone Grader SP-650. It is available in about 2 weeks.
We grind A2 all the time with no issue so we need to speak. Please PM me and I will talk through a solution.
Martin
