Hi folks
My father-in-law (also a woodworking nerd) is visiting us at the moment and he brought his current woodworking problem with him, how kind!!! He's making a chest of drawers out of ash and whilst making the frame (frame+panel construction) he ran into this problem. He was routing by hand a stopped groove for one of the side panels, so he was routing one of the legs. Whilst pushing the router along the leg the side fence of the router somehow hit the workbench and the bit veered off and through the part of the leg he wanted to keep! Yes, I know, I know.
My suggestion is to mount the leg part on a horizontal table of the Woodrat and clamp it so that you can wind the leg left & right under the router in order to cut out the broken part of the leg. On the Rat the router bit can be plunged in view so that only the parts you want to remove are removed. Then make a thin wall section to glue back into the leg to complete the groove for the side panel. Unfortunately it will be seen as it is an external part of the leg.
Does anyone have any other great ideas?
Steve
Steve
