Yojevol
Clocking on
I've had my vacuum press outfit up and running for a couple of years but the bag is too small for my latest project. A new bag of the shelf was going to cost a lot of dosh, so I decided to make my own.
Here it is in use for the first time today:-
I purchased 4 x 1.35m of .5mm clear PVC from Allplas, cut it in half and joined the long edges with double sided sticky tape. I left both ends open to allow easy insertion of the work piece.
The end seals are made of dowel and blue water pipe with a lengthwise strip cut out. All for a cost of no more than £50 including a few basic plumbing fittings for the hose connection.
The project is an elliptical table top made of 22mm MDF clad on the upper side with 2mm veneers of American Walnut and lipped with strips of solid AW. The underside is being covered with ordinary AW veneer just to hide the MDF. The veneer is going on in radial bits because I had a lot of bits and pieces left over from my previous project. That is what is going on in this photo.
I hope to put more pics up as the job progresses.
Brian
Brian
